Yasko
Senior Member
Yesterday I had dual lights, and today I don't????????????
Hi, and low work, but no more dual low.
The right side headlamp bulb is a dual filament H4 lamp and the left side is a single filament H7 lamp. Do one of the lamps have a blown filament?![]()
No light on the right with low. What model bulb do I need for the fix?
I guess the low beam filament on right could have burned.
Like others said only one low beam from factory so if it had two it was a mod. Need to check and see if you have two wires to the right head light and then you'll know if it has a mod. Then track it back and see if there is disconnect.
Sent from my Desire HD using Tapatalk 2
IF THE RIGHT SIDE WAS MODDED, it have THREE wires to the plug, not the factory TWO.
If there's only two, its still stock and ONLY high beam will work..
And yes, you can use the correct style automotive bulb. As Cliff mentioned, each side uses a model different bulb.
**Just to reiterate, if there's TWO wires to the right bulb (as you sit on the bike) and the high beam works, the bulb is fine, the bike is working as it was designed..**
You want an H4 - an H7 only has one filament.
I got a new bulb today. When I tryed to change the new one, the old one started to work.:rockon:
Got a loose wire or bad ground somewhere, likely at the plastic connector...
