Warm up?
ewink5
BigMonster
Durham, NC, USA
Not really. But not wise to first rev up engine during cold days. Start out with slow riding. Your temp gauge will indicate low temp, until about 120 deg F. Common sense mostly.
arsity
Michigan
I normally just wait for the RPMs to drop a little. During that short period of time, I'm busy putting on my gear.
yamihoe
Professional test dummy
kennesaw, Ga
just dont get on it good till the bar stops blinking, it really doesnt take that long for these bikes to warm up...my commute is 2 miles and it is warmed up by the time i get to work....
mave2911
South Australia
On a cold day, I let my bike warm up until the idle drops as the choke closes - usually 1-2mins.
During that time, I'm putting my helmet and gloves on.
Cheers,
Rick
Gelvatron
Southern Cali
The ecu runs open loop when the engine coolant temp sensor is not telling the computer it's warm which means the. Computer doesn't optimize any outputs it's really only running on pre programmed outputs not reacting to the inputs by the sensors, so it's best to allow the engine to run in close loop which means allowing it to warm, easy to that by starting then getting your gear on.
PPieter
Belgium
How about yourself getting warmed up? :D
I always take it slow the first 15 min to 'get into it', after that I start driving faster and faster in each turn.
Cheers,
Rick
+1 on the above.
Besides that, I'll (if possible) keep the RPMs/speeds (for me under 4-5K RPM's) slower than normal until AT LEAST the coolant gets to temp.
Even at that, the coolant may be at 180 degree's, the oil IS NOT. I'm fortunate enough to have areas I can take it easy until fully warmed (coolant and oil). I definitly DON'T rag it until its FULLY warmed up, including the oil.
Yes, the engines are about bullet proof but its still an engine, common sense will make your engine last a long time...
Yasko
Senior Member
D/FW Texas
It takes a couple of min. to roll the bike out, close the door, get my gear on, and lock up. That was enought time for the carb. 250.
Thanks guys.
kawkx500
WESTERN PA
my bike never moves until the temp gauge reaches at least 130. It doesnt matter how hot or cold it is outside. After 130, then i run it.
FIZZER6
The Angry Blue Mantis
Virginia
^This! You will actually burn more fuel by riding before the engine reaches operating temp than if you let it warm up 2-3 minutes. Use this time to put your gear on, load up your luggage, etc. It's also better for the lubrication system to come up to pressure and temperature with no load on the engine.
david323
Can't Re Member
Chandler, AZ
I always start my bike, then TCLOCK (well, not the oil), then gear. By the time I'm geared up the bike is warm and ready to go and I still take it easy for about 2 or 3 miles (e.g. until I hit the freeway).
