... so the saga continues....
Next came mounting up the light assembly. I didn't take as many photos, I was rushing to beat darkness, so hope it's still clear enough.
Parts and tools:
1" x 1/8" aluminum flat stock - 12 inch bar more than enough
1/4-20 button head stainless allens - 2 that are 1.25" in length, 2 that are 1.75" in length (upper ones), and several washers to stack up as shims, and nylon lock nuts x 4.
10/32 button head SS screws - 4 screws, 5/8" long + washers and lock nuts.
Mount hoops and rubber as listed previously - you need to cut 1" strips from the rubber sheet. The 2008 has a 43mm diameter fork as i recall, not sure on other years. You may need thicker rubber for a thinner fork tube... or stack two layers I guess.
The final setup looks like this from the side.
This gives you an idea of the how the tabs mount (this was just a mock up, finished parts were nicer). Bottom ones face inward, tops face out. The lower tabs are 1-3/4" from the top of the lower fork clamp (if measuring inward-edge to inward-edge of each part)
I cut some mount tabs from the Aluminum bar. You can see them in this photo, to the left of the light. The lower ones have holes spaced 1" apart, while the uppers have a slotted hole to allow for adjusting the final position a little bit. The upper have a distance that can be adjusted from 1/2-to-3/4" apart if measured on hole centers. Drill holes accordingly to allow for the 1/4-20 and 10/32 screws to pass though.
In the photo above, check out the large washers I have stacked on the top TACH mount stud. You need a few here, as on the the stock part the mount plate is offset about 1/4" from the other two mounts. This actually comes in handy, as you can add or remove washers to adjust the final angle of the TACH. There are 3 large flat button head allens that you removed from the fairing earlier, these are used to mount the cover to the TACH,
after you have used the coarse plastic screws secure the TACH itself to the mount plate with rubber grommets. (Note: The screws for the cover will need some elbow grease, as you they are making new threads in the plastic when you screw them in)
Bulb and wiring. Pull a bulb from your old headlight set and install it using the reverse of the removal method (there is a little hook to unhook the spring) I plugged the main plug to the bulb so it's always on on my naked; I didn't bother with the little running lights as I always want the headlight on. This bulb appears to be a double filament, so I suppose it's possible to get little creative and wire that second filament up if you wanted a hi-low beam etc. Maybe search the boards for this. Honestly, the single light sucks so bad I don't think I would want to ride at night with it other than down a freeway where other cars are lighting the road. I am a total lighting snob though so that's worth keeping that in mind as far as that comment goes. Or, you could probably mod this with a HID projector setup like other have mentioned. I don't plan to ride at night with this rig.
Loose wires get zip tied together into a little peanut looking bundle and stuffed to the side next to the fork. The horn I reattached to the original location. After a little flat lack spray paint it almost 100% vanishes.
Mounting process.
1) Install the fork hoops, rubber strips and mount tabs. The lower hoop is 1-3/4 from the lower tripple measuring edge-to-edge. The upper is then 5" above these if you measure between the screw holes. Note above photos for reference.
2) Install the dash panel. Measure from each panel tab to the fork tube to make sure you have it on straight, then tighten it on down with the screw underneath the upper tripple.
3) Mount the lamp assy on the lower 2 mounts, so the light is swung outward and you have easy get access to the wires. Wait to tighten these obviously.
4) Dangle the horn wires out the bottom of the light for later hookup. Pull the tach plug upward for later hookup as well.
5) Attach the turn signal plugs, then zip tie together (or electrical tape) all the loose harness wires together and stuff them in place beside the head tube (not much room when it's all done)
6) Plug the light in, and turn the bike on to make sure you have the correct plug hooked up (the one that lights w/o the high beam switch on).
7) Next, rotate the light upward and attach the upper 2 mount screws (this is fun). Some wires may need to be pushed out of the way etc. The plastic brackets on the light sit right under the upper fork tripple if you did things right. If all looks good with the angle, screw all the mount screws down (don't go to hard here, thats why you used lock nuts after all)
8) Mount the tach, screw it down then mount the cover.
9) Mount and hookup the mount the horn in the factory spot.
10) Start it up and adjust the light angle. There are two screws that move the light bulb up-down and side-side (they have jagged edges) . You can get screw access if you turn the handle bars all the way to the side. Finding center becomes trial and error.
Thats it for now I think ....mirrors, fender eliminator project, and new turn signals to follow.
-Chris
