My FZ6's fan switches on at 100C (212F) and off at 95C (203F), and will continue to run regardless of whether the engine is running until the ignition switch is turned off.
Can someone from the US confirm that this is also the case for the US models?
Once the engine is turned off, leaving the fan running isn't really going to help much as the coolant is no longer being circulated around the cooling system by the water pump.
I wouldn't say it's particularly necessary, but you would do better to leave the bike idling for a minute or two before turning the engine off, as the fan will be running whilst the coolant is still being circulated, cooling the engine much more effectively.
Hope this helps,
Yamahaboyz
