- Joined
- Feb 7, 2009
- Messages
- 12,920
- Reaction score
- 1,725
- Points
- 113
- Location
- Cape Coral, Florida, USA
One hose nipple I believe, is attached just below the filler cap(it internally has a steel line running up inside the tank)... If when fueling, the fuel makes it up too high, the fuel will run out that opening/filler/hose instead of down the tank. If the tank is very full and left in the sun, the fuel will expand some and again vent/leak out the overflow..
The other nipple should be for strictly venting the tank. If it wasn't vented obviously, you'd develope a vapor lock.
You can blow some air (doesn't need to be alot, 10PSI) thru the lines to make sure their clear... IMHO, I would disconnect them at the bottom of the tank, blow out the hoses downwards, and for the tank itself, upwards..
Pic's are from my old 07 tank, about 1.5 years old..
