Shinn
Before doing any spring changes ride it before you decide. I had 1.00's in my bike then added the intiminators and I was shocked the bike was almost like a piece of 2x4 up front, stiffer then a tree.
They are on sale for $179, it's about time to change the oil again and this looks like a simple change with better control. Changed my fork oil for a heavier weight and like the difference but don't want to go too stiff on the front so stock springs and the intiminators are enticing.
Yeah, that sounds like a plan.
What about the fork oil weight? If Ricor says to use 5W oil and the stock oil is also 5W, wouldn't you be stuck with the original damping curve (as was previously stated)?
If you used lighter oil, the stock damping wouldn't be limiting you, but will the Intiminator work correctly anymore?
What oil are you running and have you drilled your damping rod holes/orifices/whaddaya-call-em?
Nice post, Please keep us informed after the snow melts which should be soon for you!Great questions. I will look into the scientific answer, as I have no idea. But as far as my butt on the seat answer, I went with a 10wt after trying 5 and 7.5 as well. I found the 10 still allowed the forks to move and feel normal with my springs and intiminators. Never drilled anything as I was told by my mechanic that it wouldn't actually help with intiminators.
And now for the science in my less then technical terms of which I just looked up and hope I am comprehending right. The thicker the oil, the greater the time it takes for the chambers to refill or it can cause air pockets and not having the forks reset in time for the next bump (hence the term rebound). On the other side, the thicker oil takes longer to push through the compression holes making the fork stiffer.
So if I am comprehending this correctly, ricor suggests 5w in order for the fork to still move freely into the chamber and past the intiminator and still work for rebound. Less weight oil will make the rebound faster, but also make the compression harder on the intiminator and as such the fork should dive a little faster. Now I am going to test this as soon as my snow melts in 2-3 months. Love the questions, lets keep going!!
