Stealth94
Was just curious on the best method...and if you need the forks on to do so correctly/easily lol. Thank you
Hello,Was just curious on the best method...and if you need the forks on to do so correctly/easily lol. Thank you
I believe you have a full cradle frame (the engine isn't a stressed member)...
Good luck
Pending on location, an open truss garage is pretty handy as you can run tie-downs through the truss and around the bars and tail (may need extensions of some kind). While actively working on it, a tie-down through a wheel to a support object provides for/aft retention. Your auto or a stand off pipe like those used to protect furnace/water heater can be helpful too.
Floor jacks are a must. . .
