dieselman88
hey everyone, new to the forum here. i was just curious if it were all possible to switch out the engine on our bikes to say an fz1 engine or maybe even an r6. if you got the engine, ecu, harness, air box off the donor bike
sorry chevyfazer but I would double check on that bolt in r6 engine advice. I believe that the mounting points are different.
I tried added this in but most of the time i use a voice typing app on my phone and if i hit backspace it delets the whole sentence but yes the mounting points are different but with the way it is designed only a few brackets would be needed to bolt it to the frame but a lot more would be need to get it running but after looking at a complete parts list with part #s from yamaha for our engine vs a 03 r6 the only differences I see are in the head, they have the same pistons, same crank so I dont see why you couldnt just slap a 03 r6 head on one (with the proper tuning) and make pretty close to the same power
The problem with using any engine that doesn't bolt in directly is this: The stock engine is actually a structural part of the frame, adding to the rigidity of the frame. By changing the motor and using brackets or what have you to get the engine to fit, you change the stresses on the frame, potentially causing some major problems.
Yes if you get billy bob with a stick of pig putty or jb weld to put it together but im a metallurgicalist/fabricator and come from a long line of machinest so if I were to do it it would be just as strong as yamahas original design or better but there are many billy bobs out there who like trying to make chicken salad out of chicken sh!t so it all comes down to how far you are willing to go...I would love to be able to do it but it just dosent seem like I would be happy in the end for all that work for a 20hp gain...but then again ive always been "that guy" who dose something just because someone says it cant be done
That's all well and good, but there's more to it than just fabrication skills. You need to analyze the stresses that's being imparted into the frame and the motor and make sure that everything is happy. There are engineers in this world for a reason.
Doable. Yes, especially if you have a friend that's a machinist.
However if most states are anything like NY, once you touch the frame your insurance, registration and title are null and void because it's No longer a FZ6 in their book. I think they list it as a custom, and you have to get it checked out by the state, get it's own VIN number and find an insurance company to cover you (Expen$ive). IMO if it doesn't bolt right in you'd be better off just buying an FZ1, it will probably be cheaper.
thanks for the input. i really like my bike, but just wish it had some more power. swapping the heads/cams from an r6 seems to be the easiest but i dont really think its worth the trouble
Ive never herd anything like that about insurance or what not, if someone was to do something like that couldnt they just not let them know or how dose it work up there?
how much of a gain do you get from r6 cams?
