ChevyFazer
Redneck MacGyver
on my way home from work my bike started running real ruff, breaking down at idle and while holding constant speed, if i twisted the throttle back a little and put the engine under a load it would begin to run smooth, when i came to a red light the check engine light would come on and then go off shortly after i took off. I did do some work to the fuel tank sunday and i was thinking my fuel filter might be getting stoped up so i tried tossing the bike side to side at the redlight and poof everything turned off as if i pulled the key out and my speedo began to flash like it dose when you first turn the bike on about once every few seconds, after a few min the bike came back to life and i went on my way still running ruffer and ruffer and about 8 miles after the first shut down i was driving down a short straight and it did the same thing this time i pulled the clutch in and released and it fired right back up and began to run smooth the rest of the way home so im officially puzzled so someone please help me
