iSteve
Your right 86 not 85. I used 91 last year but with prices this year 89 will be my choice.
I used to work for Magellan Pipeline and at the moment I work at an airport and get to see where and how all sorts of different fuels are used. Trust me the Premium to Regular is like Grey Goose vs Hawkeye vodka in some cases. But at any rate don't be putting ethanol in you tanks. Even though, living in Iowa, it boosts my local economy tremendously it's a load of horse **** and costs more to produce and maintain than the energy and money it "saves". And it gums up your engine faster than pure. That goes for ALL engines.
Used to be a corporate employee of a large gas station. This is simply untrue in pump gas. Octane is RESISTANCE TO BURN and that is it!!! Higher prices are related to increased difficulty refining higher octane fuel not because its better. now different gas stations have different quality standards and additives. If you are using higher octane than needed you are wasting money and if you are I can also tell you that tour bike will run cleaner and faster if I touch the tank, I offer my service for 2 dollars a tank!!!
Although our bikes can use any grade of fuel, mainly because of FI that doesn't mean there are not times higher octane could be a advantage. The FZ6 does have a 12.2 : 1 compression ratio. On very hot days, in heavy traffic, two up ridding or high RPM track days a otherwise fine running engine can suffer pre-ignition. If you ever hear a pinging or knocking on a hot day when engine is under load a higher octane wouldn't hurt.
You guys should all get on the waggon...
A lot of rider on the 6R forum are in there... kind of very addictive. I did the test. I've been using Premium since I bought the bike. I usually get 45-46 MPG within few then/mile. I tried Regular on one of my last tank. Barelly 40 MPG, so I'm back with premium...
Can you give me the 30 second synopsis on what this is?
Ok, so I took the following assumptions and ran with them:
1. Mpg goes from 40 (low octane) to 43 (mid grade) to 46 (high), which is what was stated but with a linear assumption for the missing mid grade number.
2. People drive 5 days a week (in this model) to and from work, between 10 and 70 miles, with 33 as a midpoint... because my actual commute is 33 miles and I made the spreadsheet.
3. "1 Year" is 51 weeks, even though in my case it's more like 38 with winter, but let's say this is in the south or the west coast. Either way I show a weekly and a monthly (4 weeks).
4. Gas could stay where it is (AAA avg for this date), or go way the hell up to $5/gallon for premium.
So in the first shot I leave everything as it is today but play with "Mile To Work:"
In the second, I do the same with miles to work but I crank up the price per gallon:
So it does save you money, but not a lot. Interesting.
edit: It occurs to me I didn't need to put a Gallons/Tank figure there, nor an extended cost per tank. They weren't used. -shrug-
I don't disagree. I was testing the numbers I was given, though. Easy enough to plop new numbers in. Hell, what do I get these days... 165 miles to reserve, how many gallons is that?
edit: Yep I'm getting about 42mpg right now, very consistently, on low grade gas. I will fill up this afternoon on premium and see if it comes up different, and I will know for sure if it does. I hit reserve within 2 or 3 miles of the same amount every time, 3 times a week.
