gpostarmy
This is a thread to show how you can customize your seat to have a comfort gel seat. I also address the issue of the gel holding heat/cold.
First here is a thread that will show you how to take apart your seat and shave it down. Here is the thread http://www.600riders.com/forum/fz6-mods/12885-shaved-seat-6.html You will want to take at least 1/8" off the entire seat.
Once you have got your seat shaved down, draw an outline for the gel insert on your seat.
When you have that cut out you can use 60 grit sand paper to smooth the surfaces. Use a spray adhesive to lightly tack down the foam to the seats shell.
You will also want to spray the insert area for the gel, even thought the gel is sticky.
This is SHOCKtec Air2Gel. It will help to disperse heat/cold out of the gel as well as create a smooth seamless finish.
Use spray adhesive and tape to hold it in place while it dries. You may have to cut reliefs in it depending on your shape.
Hopefully this is what it looks like when you take off the tape.
Pull your cover back over the seat. Up to you whether you want to use adhesive.
View attachment 34466View attachment 34467
I got the gel and the SHOCKtec Air2Gel foam SHOCKtec Gel & Air2Gel HOMEPAGE
The gel is the motorcycle seat insert Standard (12"x18") $34.95
I got the 1/8" SHOCKtec Air2Gel full roll $33.20
The customer service for this company was outstanding. I initially contacted Tom Pierce, he more than answered my questions about what I wanted to do, I placed my order online. I received an e-mail with invoice and tracking information. I also got a follow up email to make sure that I got the products and that they were what I was looking for all from Tom Pierce. Like I said, great customer service.
