Do a leakdown test on your engine and see for yourself. Not a perfect way but cheapest tool wise.
I've built over a hundred racing engines in my life. And I'm not talking about just putting an engine together. All the machine work that goes with it also. With Total Seal or any gapless ring we like to see 2%. With conventional gap rings we are happy with 7%. You cannot have a perfect seal and zero blow by with a metal cylinder and metal rings going up and down the cylinder. There will always be leakage past the two metal surfaces.
There's my source, experience and knowhow. :Flip:
So you're talking cold metal and cold cylinders. I can follow that. Would you agree, that once an engine starts that the rings expand? As they have much less mass than either the piston or the cylinder wall, they expand fastest and furthest?
Isn't that why standard rings have an end gap? Don't the 2 or 3 rings in most designs further reduce that leakage, especially as the gaps are supposed to be offset?
I've been led to understand that almost all blow by occurs before the engine warms up.... obviously, there's still a relatively slight amount when everything's up to operating temps. There is still a gap between the ring ends, however slight.
The fluttering of the rings as the piston changes direction and deals with the combustion pressure change are going to alter their sealing characteristics as well.
If an FZ6 engine lost 7% of the cold air charge into the crank case on each cylinder with every combustion cycle, that would mean every crank rotation would 'dump' 21cc of fuel/air into the cases (two cylinders). Multiply that by whatever RPM you're running, and you get to many liters per minute. Idle @ 1500 RPM X 21cc = 31,500cc... 31,500/1000 = 31.5 liters.
I find it hard to believe that the breather hose between the crank case and the air box is designed to handle that much flow. Especially when (if that ratio stays consistent) when you're at max RPM (North of 12K RPM) that volume goes to greater than 252 liters/minute.
I don't think you can get that much air through a 3/8" hose.....
