ant_mb
Super *********
Finally decided to take the FZ out for a spin on Friday, after about a month of non riding. Pulled the cover and cranked it up. Noticed right away it was ideling really rough, but though it would go away. I let it warm up and set on my way. Got to the first stop sign and damn near dropped it as I tried to take off. It was missing really bad and died as I released the clutch. I thought it my be clogged injectors so I restarted it and continued on my way. Once I got to around 4000 rpm it cleared up and ran great. I purposly rode high rpm(10,000-13,000) to try and blow out any crap on it. Didn't work!
What I've done so far:
1. Drained the tank(a real PIA)
2. Checked filter
3. Checked fire to all cylinders
4. Checked TPS in Diag mode
It counts 16-101 smoothly
Not sure what it's suppose
To be?
5. Reset idle to about 1400
6. Unpluged battery for about 30
Minutes
7. Sprayed carb cleaner down the
Throttle bodies.
None of this has helped any.
My next steps:
1. Pull the plugs.
2. Run seafoam/injector cleaner.
3. Sync the TB's
4. ????
Is there anything else you guys can think of?
2. Checked filter
To be?
Minutes
Throttle bodies.
My next steps:
1. Pull the plugs.
3. Sync the TB's
4. ????
