Thank you so very much JMAN.
In my case your instructions served to verify my work since I found them after I did the installation
I did have the same problem with the same screw a couple of people have mentioned here, I replaced those screws.
I still need to try to move/adjust the shortest can since it touches the bottom extension/support for the license plate/turn signals holder.
I indeed did not disconnect the battery. I'll have that pending to do.
So, now what:
1) Disconnect the battery for new auto-adjustment of the ECU. I'll do this
2) Custom map (Dyno). Is it really necessary or not needed after auto-adjustment of the ECU?
3) Power commander. What is the advantage of this? If I'm not mistaken, you have customs/preset maps and can also have manual control of the gas/air mix - I'm sorry but I'm not too knowledgeable about this!!!!
I left the DB killers.
Have you guys found any noticeable performance improvements?
Do I need to follow most of the options listed above (I do not know if there are any more) to find out about performance improvement?
I have also read about millage/gas improvement with aftermarket exhausts, any comments on this?
Thank you,
Angel
