Temp Gauge stuck at 100 F
RandyC
Baton Rouge, LA
I was riding today and when I looked at my temp gauge it was stuck at 100 F. I pulled over and shut the engine off and restarted my bike and the temp retuned to normal (178-185 is normal cruising temp for mine). Has any one else ever had this happen to them ? Is there a sensor wire that might get loose and cause this or is this something not to worry about ?
Thanks,
RandyC
Your bikes got the 'Brain Rust' and only has a few miles to live.......... :BLAA: naw seriously though it sounds like a little internal logic lock,and you performed a global reset by cycling the key....... I would put dielectric grease in every electrical conection you can find to prevent any further problems... :rockon:
Mine did that (reverted to intake temp) about ten times in the first 3000 miles without touching the reset or select buttons, it did it on a hot restart. Was considering reporting it to the dealer as it's on warranty but lately it's been fine.
