sixsix
Seems i´m having the spacing problems aswel.. time to put washers in... stupid bracket
Loosen everything up and pull them apart. You shouldn't tighten anything down until they are lined up.
Been there doen that sadly.. check how far they are apart
Cheers, that's what I did! They are mounted.... but.... now the mid-pipe is touching the steel frame on the right. Can that do any harm or can I just leave it as is?
Hey folks, my Leo Vince Titaniums should be here in 48 hours. I am sure this will help tons. I did have one question though... I understand that there is one screw to to remove to take out the dB killers.... I was planning on starting without them installed. I have heard in searching that they can be a little tricky to remove. Is that due to running for a while with them and then taking it out, or just very snug? I also hear the screw is a "safety screw." aka it is made in such a way that it is very hard to take out.... any light on this would be great. Thanks ahead of time.
the rpms still surged at idle..maybe about 200rpm or so. I tried disconnecting it again today and its still happening. Strangely enough it doesnt happen once i start riding and come to a stop. Anyone have any ideas?
I would like to adjust my idle if i knew where it was (any help).
Bear with me, tried to do an extensive step-by-step for everyone who is considering this. First thing is to dis-connect battery so the electronic control will reset for the new exhaust flow. I left it undone for the whole install.
