The battles over which is best, a supercharger or turbocharger are no less interesting than the age old Ford versus Chevy conversations. In this case, we're talking about two different methods of achieving the same goal. In the most technical of terms the turbocharger is a supercharger however, its methods for achieving the same end result are much more difficult to tune and install. The turbocharger also has reliability issues not found in the common blower (note that a roots type blower will likely need an intercooler too). In either case they are both designed to compress air and force more air molecules into the engine's combustion chambers than would normally be allowed at atmospheric pressure here on Earth (14.7 psi at sea level).
Typical peak operating speeds for a supercharger (blower) are around 15,000 rpm for the screw and roots style blowers and 40,000 rpm for the centrifugal style blowers. Now this is where things get interesting for the turbo lovers because the turbo units typical operating speeds are between 75,000 and 150,000 rpm. So what does this mean? The turbo is capable of producing more peak power than the blower because it can easily reach boost levels of 25psi providing the internal parts of an engine build can put up with it. Typical street boost for a blower is between 6 and 12psi although they are capable of way more for the likes of an AA/FD. In either case the limiting factor is operating rpm.
The blower is often considered to be the easier method of forced induction for most street and race vehicle applications where the turbo will always be the more difficult mod considering the added work required to install them and get them dialed in. The turbo does however have its place in a more specialized market. Blowers generally provide a much broader powerband that most drivers are looking for with no "lag" at all. In addition, they are more practical for a home or novice do it yourselfer. In either case be it your choice for the blower or turbo, we get to go faster and have way more fun with a twist of the throttle or a stomp on the gas.....
