VenturiSection
Does anyone know the clutch spring stiffness for a 2006 FZ6 Fazer.
I'm currently involved in building a formula student vehicle that runs a Fazer engine with a supercharger. It produces around 80hp and over 100Nm of torque. Low horsepower due to use of 19mm restrictor. The engine is also running on ethanol. The throttle has to be upstream of the restrictor which means the engine has to be remapped etc.
The plenum needs a backfire pressure release valve as we're in the phase of trying to tune it and sort out the ignition timing and I'm trying to find out if we can use the clutch springs from a different engine we have lying around to make a pressure release valve.
you can check out the project here:
Chalmers Formula Student
we aim to be running a carbon intake with intercooler cores asap as our intake temps otherwise are in the region of 125 degrees so our old car had some cooling issues.
Any help would be greatly appreciated! and i'll put a mention in the next newsletter we do to all our sponsors
or if anyone has any other ideas what to use instead of this spring that i can rip from a damaged motor we have! All responses are welcome!
