Power surge when wet
pointbreak
Coventry, UK
Hi. I hope someone may be able to shed some light on my bike's engine behaviour in the wet.
Bike:
FZ6 Fazer S2 2008
17K miles
Full service history
Original chain and sprockets
Behaviour:
(A) Bike will surge forward for a fraction of a second.
(B) Engine appears slightly lumpy, not smooth or like the timing is out
Throttle grip action:
(C) With a steady throttle grip position
(D) Coming off the throttle / letting the grip roll forward
I only experience the following when riding in wet conditions:
(C) can result in (A)
(D) can result in (A)
(C) can result in (B)
I never get the above when it is dry.
Has anyone else experience similar? Thanks for looking.
Kriswithak
Senior Member
Sydney, Australia
I get that sometimes normally when riding, the FZ6 isn't the smoothest ride down low, and with bad fuel it can be very noticeable.
You might find your being more careful and not sitting quite in the power zone in the right gears when its wet. I still have the stock tyres on my FZ and they are terrible in the wet till they are nice and warm, and I still find them really lacking compared to past tyres.
It could also be the humidity affecting the bikes running.
Otherwise it could be some kind of electrical problem with your throttle perhaps? I guess if water is getting inside it could be doing something bad, not exactly an expert in this area though.
RJ2112
Dahlgren, VA/USA
www.etsy.com
I'd agree that the engine is not going to run as 'clean' and smoothly, below 5K RPM as above that point.
There is a 'dead' spot just off idle, due to Yamaha trying to meet emissions requirements. With carbs, it used to be called 'lean surge'. Idle is fine, then you twist the grip slightly and nothing changes, a little bit more, still nothing.... then a teensy bit more, and you get more than you expect.
If you are riding the bike in very 'low power' conditions.... slight throttle in damp sounds like this situation, you will interact with that 'lean surge' frequently.
It sounds counter to good practice, but give the same conditions a try with more RPM. Step it down a gear so the motor is spinning ~1K higher RPM than what you went with last time, and see if it's smoother.
squirly
walworth,ny
make sure your air filter is clean very wet air is thicker but i do agree with the other replies here too. just my 2 cents!
pointbreak
Coventry, UK
Thanks for your comments. The thing is my bike never used to have this problem and I have ridden in heavy rain before. This is an S2 bike so there shouldn't be the throttle problems that can be experienced on an older bike.
I considered the throttle position sensor (TPS) but the diagonostics on the instrument panel confirmed that the throttle range was 16 to 103 with no missed values in between when twisting the throttle.
Last night I looked at lots of threads discussing the ignition coil packs and decided to investigate the HT leads, spark plugs etc.
I removed all the spark plugs and I found there was an odd one out. The spark plug connected to HT lead numbered '1' (left of bike as you sit on bike) was 'dirty'. Also it had a smell which the other three didn't. Does anyone know why this might be?
When I got my bike back from its last service, spark plug #1 chamber didn't look sealed by the HT lead plug. I rode my bike for approx. 3 weeks before pushing the HT plug all the way home. It's possible some wet got in, or some muck, and this caused the plug to be 'dirty' but the spark plug shows the entire thread is dirty compared to the others and I don't see how dirt and water could have made their way down the thread. Also it wouldn't explain why #1 spark plug had a smell and the others didn't.
I'll describe the smell as petrol or oil.
#1 spark plug does stand out from the others and would welcome your comments on why this might be.
I see two coil packs in front of the battery under the tank. Are there any tests I can do on these?
Thanks for looking.
RJ2112
Dahlgren, VA/USA
www.etsy.com
Spark plugs uploaded.
I'd have to think the #1 plug was not all the way seated at your last service. Between the boot being loose, and the 'fouling' you see on the threads of the plug..... that's almost a given. Lots of moisture and muck to form an electrical path to ground somewhere other than where you want it.
The plug is pretty rugged, but it does seem to be that #1 is more fouled than the rest. The plug wire may have been wetted enough, to ground out the spark impulse before it gets delivered to the plug. High voltage can 'jump' a fair distance... works out to about 1mm/1Kv. 25Kv.... 25 mm to jump to ground.
Look at the rubber insulation on the plug boot, and the wire itself. You may see a black, burnt spot. If so, toss the wire and install a new one. Once the insulation has been defeated, it will continue to do so.
pointbreak
Coventry, UK
Thanks RJ2112! To remove spark plug #1 I'm sure I had to use the same force as the others to initially loosen it which suggests it was fully seated but maybe it was the residue which I was breaking when loosening it.
The brown residue on the body of spark plug #1 scapes off but I'm still baffled as to how the entire length of the thread got contaminated compared to the others.
The ends of all the plugs look the same. Maybe the spark plug was installed like this or with oil on it.
I have looked inside the end of the plug boot and there are no signs of arcing or pitting. The boot looks the same as the other boots.
I suppose I should put in a new set of spark plugs check again.
RJ2112
Dahlgren, VA/USA
www.etsy.com
You'll want to trace back along that wire, all the way to the coil to inspect the insulation. The burnt mark could be quite small.... as small as a pencil lead and cause the issue. Could be, all is well there.
The only way that the entire threaded portion of that plug can get that grubby, is if fluids leak in there from the outside.... especially if the plug has continued to fire and isn't any nastier than the others at the working end. The only way I am aware of for that to happen is for the plug not to have been properly seated in the head. The crush washer typically doesn't seal in that instance, which allows the migration along the threads. The other 3 look much more typical, some discoloration near the working end, and cleaner and cleaner the farther away from the heat you get.
With the FZ having the spark plugs in relatively deep wells, that rubber boot on the spark plug wire is critical to keeping the splooge out of the plug wells.... if it's allowing water to pool in there, it will wick along the threads by capillary action. IF the crush washer is not properly compressed.
It appears that combustion gases have gotten past all the threads as the plug wasn't fully tightened(from the inside to the outside). Not being tightened fully is also a bad ground for the plug itself and will cause problems.
Besides replacing the plug and torquing to the proper value I'd check the wire ends as previously mentioned.... I'd replace the wire if there's any doubt its integrity. Hopefully lack of a good ground didn't damage the coil/ignition. I'd put a bit of di-lectric grease on the boot end when re-installing it. Keeps water out and easier to install/remove later.
If possible, look down closely for any cracks (not likely) in the head where that plugs goes in....
Looks like 'blow by' through the plug thread area. Even if the plug seemed seated with a crush washer. I would still try to see that there is no other obstruction that could allow the plug to seemingly be seated as the rest of the plugs, but in fact be not sealed. Could there be an anomaly on the thread in the head that is allowing gases to blow by? It looks as if that cylinder is firing just a bit differently from the others. This in turn may have deteriorated that one insulator allowing a High V. path especially during wet conditions, hence the misfiring. Wire brush and inspect the plug itself very closely. There's got to be a reason those gases took that path!
pointbreak
Coventry, UK
Thanks TownsendsFJR1300 and Motogiro. My bike is due its 18K service (currently on 19.1K). Going to book it in tomorrow at a Yamaha dealer where I always have it serviced. I'll report back when it's done. I'm confident I can get this issue sorted given everyone's input here. Thanks again.
pointbreak
Coventry, UK
Had bike serviced yesterday. They identified a problem with ignition system, finding a 'corroded cable in the electrical block' (I don't know where the electrical block is located). They removed the corrosion, refitted and covered with grease. I'd been having hesitancy with the engine when leaving it overnight and letting it get damp or when riding in wet conditions. This should be cured now.
Regarding the spark plugs, the dealer said they saw no difference between the spark plugs and that they all looked like new. They confirmed that nothing was escaping up the spark plug threads of cylinders #1.
Now I've got a new set of spark plugs I'll check them after a few thousand miles.
Thanks for all your input guys. Maybe this thread will help someone in the future.
pointbreak
Coventry, UK
I still have the problem of a hesistant acceleration when it is wet so have begun to inspect the coils and the spark plug caps.
(The electrical block mentioned earlier which the dealer said had corrosion can be seen as the left block of the two blocks in the front left fairing shown in picture #1 ('Location of work.jpg'). They cleaned the connections and applied silicone sealant. So this hasn't cured my engine hesitancy (and I'm not sure why it might have) when wet but unfortunately my right front indicator stopped working earlier in the week. I replaced the bulb but it turned out to be the electrical block above. I used 1200 grit paper on the pins and my indicator is fine now.)
Picture #2 ('Coil close up.jpg') shows spark plug caps #1 and #4 connected to the coil. I want to check the resistance of the coil and have tried to get the leads out of the coil but they wont budge. I have damaged the plastic clip whos purpose seems to be to hold the leads into the coil.
Does anyone know how to get the leads out of the coil? Thanks.
pointbreak
Coventry, UK
Ok, I don't think the spark plug leads are meant to be pulled from the coil. (Don't know why the plastic clip is on there).
The specification of the coils is:
Yamaha Fazer FZ6 S2 2007 Service Manual ENG
Page 375
Primary coil resistance 1.53-2.07 ohms at 20deg C
Secondary coil resistance 12.0-18.0 KILO-ohms at 20deg C
My readings (approx. 15deg C):
Coil (#1, #4): Primary = 3.1 ohms, Secondary = 33.1 kilo-ohms
Coil (#2, #3): Primary = 3.1 ohms, Secondary = 33.8 kilo-ohms
Even though these readings are not within spec I don't think they are faulty as both have the same readings and what are the chances of both failing at the same time? And if they were both faulty I'd probably expect worse symptoms than I have been experiencing.
I'll have to go back to the dealer.
RJ2112
Dahlgren, VA/USA
www.etsy.com
Page 375
Is the power to the coil provided through that corroded connector 'under' the leads, in the photo?
If there is a bunch of munge in there, that would short out on the low voltage side.... on the 12V input. Open that connector back up, and take a very close look at the contacts, and the plastic to see if you can spot a blackened area, where current flows to ground through the connector body.
This would be an excellent example of where dielectric grease should be applied....
If the bike will act up at a stand still, you might try raising the tank and squirting (a mist) a small amount of water where the moisture would be collecting and try to duplicate the problem. If its dark outside, even better, you may see the coils grounding out/jumping, etc...
If your still under the tank and the bike half apart, I would unplug as many connectors you can reach, inspect them, then apply di-lectric grease to ALL connectors. Its good preventive maintainance and you may luck out and find where a wire is arcing/etc. Check all grounds as well...
Good luck...
pointbreak
Coventry, UK
Hi RJ2112. The corrosion shown is on the bracket of the coil which is used to connect it to the battery surround. The bracket has a metal back-plate which is corroded. Picture #1 shows the low tension spade connectors (2 no.) on the right-hand end of the coil which are clean, as are the female connectors which push onto them. Thanks for spotting that.
Thanks TownsendsFJR1300. I like the idea of trying to produce the conditions which might replicate the problem. I have no problems at standstill though. When it is wet next, and after having experienced the problem, I'll pull over and have a look under the tank to see how far water penetrates although I do get the problem if I leave the bike outside overnight without rain and ride to work in on a dry morning - which suggests the smallest amount of moisture is causing this behaviour.
I'll pull all the plugs apart and inspect them. Thanks.
