Hello fellow members, I would like to call upon your wisdom. I am in the market to buy a FZ6 but are there any years that might be better to buy than others? I have looked at a 2007, and the seller said not to buy one from a previous year, why? Thanks for any and all replies, Kristian!
In the end it's not the years in your life that count. It's the life in your years.
Can you spot the differences?
2006
• Type: 600cc, liquid-cooled, DOHC, inline 4-cylinder, 16 valves
• Bore x Stroke: 65.5 x 44.5mm
• Power: 96.55 HP (70.5 kW)) @ 12000 RPM
• Torque: 63.10 Nm (6.4 kgf-m or 46.5 ft.lbs) @ 6400 RPM
• Compression Ratio: 12.1:1
• Carburetion: Group Fuel Injection, 36mm throttle bodies
• Ignition: Digital TCI
• Transmission: 6-speed w/multi-plate clutch
• Final Drive: #530 O-Ring Chain
• Suspension/Front: 43mm telescopic fork, 5.1″ travel
• Suspension/Rear: Single shock, adjustable preload; 5.1″ travel
• Brakes/Front: Dual 298mm floating discs w/2-piston pin slide calipers
• Brakes/Rear: 245mm disc w/single-piston caliper
• Tires/Front: 120/70-ZR17
• Tires/Rear: 180-55-ZR17
• Yamaha FZ6 Dimensions:
• Length: 82.5″
• Width: 29.5″
• Height: 47.8″
• Seat Height: 31.3″
• Wheelbase: 56.7″
• Rake (Caster Angle): 25.0º
• Trail: 3.8″
• Fuel Capacity: 5.1 gallons
• Dry Weight: 410 lbs.
2007
Type: 600cc, liquid cooled, DOHC, inline 4-cylinder, 16 valves
Bore x Stroke: 65.5 x 44.5 mm
Power: 96.55HP (70.5 kw) @4750 RPM
Torque: 63.10 Nm (6.4 kgf-m or 46.5 ft. lbs) @6440 RPM
Compression Ratio: 12.2:1
Carburetion: Group Fuel Injection, 36 mm throttle bodies
Final Drive: 0-ring chain
Suspension/Front: 43mm telescopic fork, 5.1” travel
Suspension/Rear: Single shock, adjustable preload; 5.1” travel
Brakes/Front: Dual 298mm floating discs w/4-piston calipers
Tires/Rear: 180/55-ZR17
Length: 82.5”
Width: 29.5”
Height: 47.6”
Seat Height: 31.3”
Wheelbase: 56.7”
Trail: 3.8”
Fuel Capacity: 5.1 gal.
