Doorag
Senior Member
Has anyone tried 'modding the flies' on an FZ6? I know it's poplar on FZ1 models. Would it do the same for an FZ6?
Sorry but what are you talking about?
YouTube - FZ1 Video tutorials - Flies Mod
They are the intake valves that sit inside the stacks where the air gets sucked into the engine from the airbox. On FZ1s, a very common mod is to replace the stock ones with slightly smaller ones - allowing better airflow into the engine. It improves midrange response apparently.
TBH I have no idea. Check out the threads about it on the FZ1 forum. Most people who do it really like it "Best mod under $50" etc...I'd like to know more about this. Does it change idleing charachteristics, etc.
um.... yeah... our bike doesn't have those....
AH HA! Yes it does! :Flip:um.... yeah... our bike doesn't have those....
OK, I'll go ask some of the guys on the FZ1 forum and report back. If it works on those, in theory, it should work on ours too.
I looked into it more, FZ1 is electronically controlled, does that make any difference? Mine move when I twist the throttle.
by the looks of the fz1 set up they are secondary buterflies the alloy ones in the fz1 move via a servo motor like the exup system and the goldly coloured ones move with the throttle. the ones out fz6sare only the main butterfys and no secondry like the fz1. do not touch the butterflies in your throttlebodies! the only way the mod the throttle bodies on an fz6 is a sync. do not do anything else to them or all you will do is cause trouble
Yeah OK, my bad. I stand corrected. I'll go stand in the corner for a while and think up another dumb post...![]()
