Power Commander & Juice Box??? Help...
drkester_dmd
Philippines
Hi
I Just did some Mods to my 05 FZ6- "TB Carbon Slip-on" and it's great, one of the best Mods I did so far. Here's this "Juice box and Power Commander". Can anyone in layman's term tell me the difference between the two. What does the Juice or Commander do to the stock bike? Do you need one, both, or none? :D
Thanks Guys
PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5, PC5
Well you get the idea.
My post from the FZ6R side of the house:
I'd recommend a Power Commander over the Juice Box and Juice Box like products. The Juice Box allows you to ONLY add fuel, not take away fuel. It also only makes mass fuel changes over three very vague areas. It does not use a map and the Two Brothers tuning solution is to "play" with it, not exactly a precise process.
With a Power Commander V you can use the supplied maps, but as others have said get a custom map created. The PCV offers much finer and controlled level of tuning. You can adjust by 250 rpm increments and by 10 throttle positions. You can also adjust the fuel from a -100% to +350% with in each cell of the map. On a typical map that is about 400+ cells.
Even with a stock bike you can really dial in the throttle response with a good map.
:rof:, although I have the PC3 myself and love it. Kudos again to everyone who freely donated their map to this great forum.
Thanks.. Kinda confused with this map thing.. I'll look in to it. Thanks for the info so at least I see the difference between the Powr Com's and Juice's... :thumbup:
im thinking the PC5 might be better than something that sounds like it has no business on a bike.
wasnt there a guy on here running a pc5..im sure he said the pc3 maps wernt compatible..i may be wrong tho
Different maps.
An 08 FZ is the same as an 07, is the same as an '09. The PCV will work fine.
hmm, am i right to say that pc5 (meant for 2009) would be able to plug and play for 2007 fz6 just like pc3 does?
Juice Box Pro is a Private Label version of the PCV, whereas the Juice Box is a Private Label (as are the Bully from Gman Ind, Big Shot from Arlen Ness, EFI Power Programmer from FMF, etc) a Gen 3 / 3.5 from Dobeck Performance, the people that originally developed the Dynojet product line.
They also sell direct and through some vendors a second generation controller under the Techlusion brand.
Looks interesting and has a few nice features.
On a side note with the newest software for the PCV you can convert a PCIII map to PCV. What its does is split the difference between the 10% column and the 20% column to create the data for the additional 15% column with the PCV.
