fazer.rider
Super Member
hi, is there a thread on how to do this? i can't fine it :spank:
thanks
thanks
Tools you will need:
-Scissor jack (or any jack of some sort)
-5/8" spark plug socket
-3/4" wrench
-12mm socket and ratchet (or wrench if you like working slow)
First, put the bike up on the center stand and lock the handle bars. Then, place the jack on the #2 or #3 header pipe and lift the bike until the rear wheel is on the ground. If you're using the scissor jack, line up the notch with the header pipe so it won't be prone to slide on the surface of the jack. Don't lift it too much though. I haven't decided one way or another, but I think if you compress the rear spring you could be creating an unstable condition.
Next remove the bolts shown on the image below (they're already loose in the image) using the 12mm socket. DO NOT squeeze the front brake at this point. The brake pads will squeeze together and the calipers will not go back on the rotor.
Once the calipers are loose, you can rotate them and get them off of the rotor (counter clockwise for the left side, clockwise for the right side). Just let them hang and DON'T SQUEEZE THE FRONT BRAKE!!!
Now you'll get to use the spark plug socket. On the drive side of the socket, there is a 3/4" allen head that fits quite nicely into the axle pin (shown here).
Here is where it gets tricky: pull the socket out just enough to squeeze the 3/4" wrench between it and the fork. Now you should be able to remove the axle pin.
Don't get discouraged if it takes forever for the pin to come out, the threads are really fine and quite long. Simply reverse the process to get the tire back on. When replacing the tire on the forks, pay careful attention to the direction of rotation on the tire. Also, there are bearings on either side of the wheel. Don't worry if they fall off, they slip right back into place. I'm not sure if it matters, but I'm always careful to put them back on the side they fell off of.
When tightening the axle pin, use the same amount of torque to tighten the pin that you used to break it free. The manual has a specific value for this, but you can't use a torque wrench with this configuration.
Hope this helps and best of luck!
Another thing, there's absolutely no reason to remove the caliper bolts. None. It won't cause any problems if you remove it, but it's just an unnecessary step. Just loosen the front wheel nut, remove the axle, and slide the wheel out (and the rotor out of the caliper). Nothing to it.
Forgot a step!!! Loosen the fork clamp bolt before trying to loosen the axle.
There's a pinch bolt that needs to be loosened at the end of the leg before attempting to turn the axle CCW to loosen. Don't forget that, and tighten up again after the axle is back on.
You definitely need to take off one caliper.
I posted a How To: thread about this a couple years ago that shows another method.
