Finished installing my new speedo, and it rocks :thumbup:
Check it out:
So I also figure out the different timer options I can play with:
- "Target Speed Timer": basically, you set the desired speed on the speedo and initiate the timer at idle... as soon as your front wheel moves, the timer starts, and it stops when you reach that speed.
Example: Reached 100mph in 7.5 seconds.
- "Target Distance Timer": set the desired distance on the speedo and initiate the timer at idle. As soon as the front wheel moves, the timer will start, and automatically stop when you reach the distance.
Ex: 1/4 mile in 10.00 seconds.
- "Top Speed Test": this timer starts when you move the front wheel, and will stop when your speed decreases. It records everything for you: distance to top speed, time it took to get to top speed, max rpm, and what the top speed was. So if you take off and go all the way to 140mph and then let the throttle go, the time will stop as soon as you hit 139mph (or whenever your speed decreases).
And finally, my favorite: the red shift light!! Currently set to 14k, with the preliminary orange light set at 13k rpms. It works great and you can keep your eyes on the road and see the big led turn on... good stuff!
Oh and my speed is calibrated perfectly, so no need to take 10% off the speedo speed anymore
Check it out:
