SANGER_A2
Super Member
Okay then, after quite a while messing around in Yenka, I had a circuit that worked. I can switch the gloves on to full power or use the PWM to change the load from 0% to 100% (I hope). It seems to work, except that Yenka can't simulate any changes between full and 0 load on the pot. It just flickers either way.
The plan is to build it in two boxes - one smaller on the bars and one larger hidden away. The smaller box on the bars will have a massive 8 wires going into it, so I will hopefully find some 8 core wire that can handle 12 volts and a 2A+.
the PWM circuit will be built on stripboard and be put in the larger box. All connections etc will be covered with my glue gun for waterproofing and so they don't get shaken to bits with the vibrations of the bike.
I used StripboardMagic to automatically build a stripboard design for the PWM (one I had built it manually for the umpteenth time). It seems okay.
I've attached pics of the circuit diagram I built in Yenka for the whole thing and the top and bottom of stripboard design of the PWM.
The next step will be to search around on the Internet and (hopefully) get all the bits from my local Maplin once I find the part numbers. Maybe even get soldering later today!
Comments will be welcomed.
EDIT: Cloggy pointed out (correctly) that my diagram didn't work (again). This is because, when I was moving the bits around to try and make it fit into the two box design and shrink it down, I managed to delete one of the connectors to the transistor. I've fixed this now and uploaded the new diagrams. One is of the PWM circuit with my bits added and one with the bits moved around to fit into my boxes.
