Entries will be judged based on the following criteria:
1) The more unexpected the difficulty of the corner is, the more "tricky" the corner will be judged to be.
2) The more challenging the corner is, the more "tricky" the corner will be judged to be.
3) The more complex the corner is, the more "tricky" the corner will be judged to be.
4) The more visibility is hampered, causing things like loose-debris/stalled cars/corner itself/traffic/your visibility to others to become horrendously dangerous, the more "tricky" the corner will be judged to be.
5) The more the corner combines elements 1-5 above, the more "tricky" the corner will be judged to be.
Note: you can enter a sequence of corners if they form one on-going maneuvre.
Use google earth to show the corner from a birds eye view. Hit "print-screen" and then open paint and right click and paste. Save as a JPEG and upload to this thread.
Good luck to all the entries!!!
