SANGER_A2
Super Member
Heated Gloves Circuit Diagram (Rheostat/Pulse Width Modulator)
Last time I got loads of really helpful advice I did this, so I'm hoping as many people will chip in again!
I've ditched my heated grips as they suck and look rubbish and bought these sexy heated gloves. They come with a Y harness that I can connect them to the battery with - but I want to be able to switch them on and off easily and vary the heat. I could have bought a heat troller for £40-£70 to go with them, but much rather fancy building my own for a few quid!
I wanted to be able to vary the voltage between no resistance at all and loads so they are barely on. I think the attached circuit diagram should do that. I want to use one of these pots as a Reostat to be able to easily knock the gloves down to half power etc. The diagram also lets me completely bypass the Rheostat for full power if it's a really cold day. And of course, I can just turn off the whole thing when the gloves aren't needed.
I used Liatro Electrical Design to create the diagram if anyone is interested. It's not bad for just doing simple layouts and comes with loads of built-in components.
Will this diagram work?
Also, can anyone suggest which size pot I need to buy? I've bought all the other bits except that at the moment. The gloves will draw 1.2 amps, which will work out to be 14.4 watts at 12 volts.
Cheers
Andy
Cheers
Andy
