okay folks, i passed. barely, i'll get to that in a minute. so i hope the information i'm dropping right here will help for all that are preparing to take the road-test, in Lodi, NJ atleast.
for starters, i had a licensed rider come with me. but if i were to just 'show up' that wouldn't have worked, b/c the tester wouldve said 'how'd you get it here', kinda out in the open, so if you have no licensed rider, you'll have to truck it in.
secondly, make sure you have all your gear. (this is NOT listed in the manual), boots which extend up and above the ankle, not necessarily leather, i used a pair of timberland work boots. jeans/pants, full sleve clothing (i wore my jacket), full leather gloves, helmet obviously, and reflective tape ont he helmet, here's where i screwed myself a bit, i got 2" refelctive candy-cane tape, and put a strip down both sides of the helmet and the back, which was more than fine for the testing instructors, but near impossible to get the stuff off my helmet (it took me a while).
3rd: the road test.
if you rent a scooter you'll be fine, and if you can't handle it on a scooter, you shouldnt be on ANY bike.
i used my FZ6, i practiced in my cul-de-sac for about an hour over a few days before.
the first part of the road test is your ability to go about 50ft, make a left turn through an angle, it's 90d and about 3.5 ft. wide, not hard, but make sure you do a wide then sharp turn in so your back tire doesnt touch the paint, then make another wide left turn, no boundaries for this, (u-turn basically), and follow along a white line for 50ft. and come to a stop with your front tire in a 2ft. box.
the next part, welcome to impossible land. this pissed me off. so basically hadda go back the other way, making right turns and thru that 90d angle box, and as you come back (mind you, momentum is not on your side, you can never really get it going) they expect you to make a double right 90d turn in a 12 ft. box and as you make the 2nd right 90d turn, they want you to stop immediately in the u-turn position, against the far line, and in between that line and a dashed line offset 18". YEAH RIGHT. just looking at it, i knew i couldnt do it, i dont think anyone could on a bike. so here's where i nearly failed the test. you lose 5 pts. for putting your foot down (did that), and another 5 pts. for going over the yellow paint (did that too). HAD I KNOWN THIS before hand, i would've done one or the other. so i got my maximum 10 pts. right there, now i had to finish the test with ZERO room for error.
the next step was 'stopping distance', now i had to keep shutting my bike off, (i have akropovic tails), so i could hear the lady instructor (by the way, i had two testers, but i think the one guy was just there to watch), so anyways, i kept shutting my bike off, and since i was bogging around, i stalled reall quick on one of my start-ups, but since it wasnt during a portion of the test, they didnt fail me, but DO NOT STALL during any portion of the test, automatic fail.
so stopping distance, get up to 15 mph, 1st gear is fine, not a requirement to get up to 2nd gear, pass through a pari of cones about 3.5ft apart. and as soon as your front tire passes the cones, get on the brakes (dont skid, i'm pretty sure that might be considered a 'dangerous manuerver' and grounds for failure, but dont quote me on that.) there's a red line that's supposed to symbolize a vehicle, make sure you stop before your front tire touches that (honestly this one is very easy)
next up, the dreaded cone test. okay every, calm down. i practiced with 1 Liter water bottles in my cul-de-sac, here's what you do. get a clear path (obviously), place your first cone. measure out straight 12ft exactly, and then 2ft. to the right polace your next cone. you should place 5 cones (1-Liter bottles, what-have-you) in a straight line, with the 2nd & 4th cone offset 2 ft. to the right.
the actual road-test cone set-up: the cones are tiny baby cones, they'll pretty much fit in the palm of your hand, so yuo really dont have to worry about your pegs knocking them over. after you come around the last cone, you make a right turn and head for that 3.5 ft offset 90d angle box, make a right turn through there and head straight, you're safe. i had no problem with this., but do practice.
the last portion of the road test is going through those same set of cones for that 'stopping distance' portion, except instead of stopping, you have to swerve left or right (whichever tickles your fancy), around that red-line. this is cake, but you cant use your brakes. some pointers on this one is watch that red line. you can barely see it, i almost asked them to put 2-cones, 1 on each end, the yellow paint you can see, but the marroon red in the sun in a black parking lot, no dice. sucks, but that's the way it's setup.
so i hope this helps anyone who's taking the test in the future in NJ. just remember, the 12 ft box u-turn is nearly impossible, so if your gonna put your foot down, DONT, just go over the line and take the 5 pt. hit.
anything over 10 pts. is grounds for failure. my isntructors were actually pretty cool, and they were impressed that i accomplished it on an actual motorcycle. they sadi: "we havent seen one of those in a long time, we dont get too many of them anymore"
also, another tip for the Lodi, NJ DMV is just go in and get your stamp, and take a ride up to Oakland or Wyckoff for the endorsement, my test was at 2:00 in Lodi, and i have the "M" on my License by 1:36 in Oakland.
and then i wrote this e-mail to the NJDMV advocacy dept.:
Comments:
Attn: Advocacy Dept.
This is in regards to the NJ MVC Motorcycle Road-Test & Manual:
on behalf of the motorcycle community, myself & fellow riders are a little concerned on how the Motorcycle Manual & Road Test are set-up.
For starters, the permit test alone is a little ridiculous. There's a question on there: "What's the most common type of alcohol..?" the Answer is "Beer", but let's be honest, what exactly does this have to do with handling a motorcycle?? (And I know, it's listed in the driver's manual so we should know it, but let's be human for once.)
The motorcycle manual, is NOT clear WHATSOEVER as to the requirements of the Road Test. It DOES NOT list in any sort of clarification of the Required Gear necessary to take the test.
Onto the actual 'road-test', was this created by anyone who has actually riden a motorcycle? what in the world does navigating through 12 ft. apart cones at a very slow speed with-out putting your foot-down have to do with riding a motorcycle in traffic? What rider in their right mind wouldn't put their foot down while making a very tight turn for safety reasons?
Is it any wonder that just about 90% of the people taking the road-test, take the actual road test on a $100 scooter rental from the local motorcycle dealer?
The manual should list the 'exact dimensions' of the motorcycle road test. Instead, someone took the time to sketch out the course, but didnt put dimensions on it.
I dont think i'm asking too much here, and i think i speak for anyone who has taken the road test in NJ.
YOU GUYS SERIOUSLY NEED TO TAKE A CLOSER LOOK AT THE MOTORCYCLE MANUAL AND ROAD-TEST REQUIREMENTS.
I look forward to a response.
Thank you!
- Angelo
