Throttle Position Sensor Issues (Are you Experiencing Poor Idle/Mileage, or Stalls?)
What are the Symptoms of a Faulty TPS?
* Stalling
* Irregual idle
* RPM Drop while acclerating or trying to maintain a constand speed.
* Drop in fuel Mileage
* Poor Throttle Response
Originally Posted by Megatron on sportbikes.net
To check the TPS values, you have to press and hold SELECT + RESET, then turn the key and keep them pressed for 8 more seconds.
It'll appear dIAg on the display, you can release them now. Afterwards use select until you see a d01 (Diagnostic Mode for the TPS)
Then it should read between 15 and 17 if the throttle is closed,
With the throttle fully open, it should read between 97 and 100.
If the values are over or below those I mentioned, the TPS should be replaced.
To leave the dIAG mode, simply turn the key counter clockwise.
http://www.yamaha-motor.com/sport/fmc/home.aspx
