Fitting end cans
DaZsLy
West Yorks, UK
Hi all,
I want to fit new silencers to my FZ6 S2 2008, will i need to get a heat shield? the oem one has a heat sheild slip on.
Thanks :thumbup:
Hi all,
Thanks :thumbup:
First welcome to the coolest forum in the world! :welcome:
Next, pick whatever system you like the best, not heat problems at all. On an 80 degree day I could hop off my bike and touch my Akrapovic mufflers with a bare hand. They were very warm but not hot.
The tip of left can (from the back) of my stainless scorpions would likely burn you if you grabbed it immediately after a ride, but I feel the whole thing runs cooler than what the stock muffler did. This is because the seat doesn't get as hot, etc.
So, no, you shouldn't need an extra heat shield. The stock muffler is more restrictive, or holds the exhaust gasses longer than aftermarket cans, allowing it to soak up more heat, hence the heat shield.
no heat shield necessary on the aftermarket, they run much much cooler. Most can grab the side of the cans after running the bike without issue,
Is it possible to change the exhausts if you have the givi side cases on,due to the brackets that wrap round the heat sheild
That depence what sort of ekshaust you go for, som`s equal? as the stock, and some you have to start with " art`s and craft" to make them fit. :popcorn:
Think it`s a thread on that.!!!! Ops that was to hastig :spank:. It was the Leo vince.... the thread I ment.
Not quite shure of the scorp`s then.
