victorb
So I picked up an '08 FZ6 that was laid down on the right side by the PO. Decided to rebuild it naked using the FZ1N headlight (cheap-ish way to get this headlight posted there: http://www.600riders.com/forum/fz6-streetfighter/13504-fz1n-headlight-parts-list.html)
This is the headlight:
All in all, fitting it on the FZ6 is a pretty simple job.. Here goes:
Part 1: Electrical
The headlight comes with a wiring harness attached to it. As the connector does not fit the native FZ6 frame connector, I decided to take it off and reuse the FZ6 wiring harness. 1st picture shows the original harness, 2nd shows what's left of it now.
View attachment 14587 View attachment 14588
On the FZ6 wiring harness, I took off the black/green wire from the left headlight and plugged it in the top slot on the right headlight plug. And that's all there is to it. You now have a wiring harness that is ready to be used on the new headlight.
I haven't wired up the running lights to the FZ6 wiring harness yet as I'm waiting on some new turn signals, but this will just be a matter of splicing up the new turn signals wires and attaching the running lights wires to it. I also plan on untapping the FZ6 wire harness completely and reroute the cables to make the whole thing more tidy. There is a lot of extra wire now that the fairing is gone, and nowhere to hide it
Part 2: Fitting
The headlight comes with an assembly to fit it to the FZ1 front end. I had to dremel a few bits and pieces to make it fit, as shown below:
In order to bolt it to the lower triple I made a simple aluminum bracket. I'm not gonna go into details as tom5796 already gave a great write up on this part; lookup his posts here and on SBN for reference.
I am now waiting for some fork clamps I ordered to attach the top part of the headlight assembly, and that should be it.
So all in all it's a really simple job that can be done in a few hours once you have all the parts needed. And I think it looks pretty damn good:
Anybody interested in doing this conversion should lookup the detailed write up made by tom5796 on his install. I just wanted to report here the few things I didn't see in Tom's thread.
More pics to come once it's finished up and on the road (and inspected by NY DMV
... I hope they won't sit on my paperwork through spring...)
[Edit] Some more info added in post #15
Part 1: Electrical
Part 2: Fitting
