No hard feelings hellgate.
luckyirishboy209: I believe I have sold a set to an 08 rider. And if you look at hellgate/mattcosta7/afrpreppie's install guides, the shifter modding is minimal. The shift rod can be replaced fairly inexpensively and would be the only part that would need to be replaced if you wanted to take the bike to stock. Poutanen has also worked up a way to used a longer shift rod with a slave shifter joint, but it requires a bit more work than the hellgate/mattcosta7/afrpreppie technique.[/QUOT
your plats are a very good idea, but i wanted somthing more adjustable and i can still have my shift linkeg hidden behind my frame. i like the idea of being able to adjust my feet position for whatever riding i am going to do, strret,track,twistys,longrides,ect. i am looking at a way to machine some adjustables. and see if i can save tons of money, i have already made the foot pegs and plats that can be adjusted, but an trying to find a way to make the shift rod work with all of the differnt settings.
