Published and reviewed papers as requested. I can bring somemore when you get done.
http://www.climateaudit.org/pdf/mcintyre.mckitrick.2003.pdf
Check page three to get a idea of what this is about. ^^^^^^^
http://www.climateaudit.org/?page_id=354 Here are alot of them for you.
Here as well written article about Manns \"hockey stick\" and how the data set is scewed.
http://www.climateaudit.org/pdf/others/07142006_Wegman_Report.pdf
These should get you started.
Also the avg temp measured where? How is it avg.? What is the data set? What if you knew the data set was flawed due to man made interference?
If you place a temp recording station in one place that is away from HVAC, Pavement, and buildings, then over time buildings are built close by, HVAC units located less than 20ft away, and pavement up to 2' from it, but you still use that data in your avg temp calculations is that right?
What if I can prove that? Would you look again?
I am not knocking you at all, I would like to present the other side of the coin to you. More than likely you do everything by the book, and expect other sceintists to do that exact same thing. What if someone can prove they arent?
