stink989
- Joined
- Jun 28, 2009
- Messages
- 514
- Reaction score
- 12
- Points
- 0
- Location
- Wellington NSW Australia
When this is finished i will edit to clean it all up a bit, add some extra pics and finish the how to so it can be linked for future referance
So i got sick of looking at the silver and went to my local paint supplier and got them the match the frame paint so i can paint my top tripple clamp and handlebars.
The tools you will need for the naked are:
5mm allen wrench
6mm allen wrench
8mm allen wrench
10mm spanner
8mm spanner
Number 2 Phillips
27mm Half inch socket with breaker bar
half inch touque wrench the reads upto 110nm
Hammer and center punch
A few rags
A soft face hammer or mallet
A few different sized taps (the thread cutting kind)
A few different sized flat head screwdrivers from tiny to medium
take some photos of the position of your levers, accesories and cable routing
remove handle bars and headlight, take your time with the electrical plugs and dont forget the ones on the brake and clutch perch, you will also have to remove the throttle side bar end to slide the switchblock and throttle off:10mm tbar socket or spanner, 5mm allen wrench, 8mm allen wrench, #2 phillips
wrap up master cylinder and mirror so they dont get scratched or scratch anything:some rages and tape
undo bolts holding headlight/speedo bracket to top tripple, should be 3 of them:10mm spanner
Undo fork pinch bolts on top tripple:6mm allen wrench
5mm allen wrench
6mm allen wrench
8mm allen wrench
10mm spanner
8mm spanner
Number 2 Phillips
A few rags
