wont start unless in nutural
Iskyone
Mass, North shore
My bike will not start unless in nutural. It's a pain if/when I stall in traffic and have to place in nutural to start my bike. I understand if the clutch is out, but not while holding it in. Any Ideas????? Thanks
ant_mb
Super *********
Delran NJ
Check the sensor plug going into the kickstand. I would unplug it and make sure it's got a good connection. I'm betting that's what it is.
Norm
Senior FZ6 Advisor
MA
I'm able to start in first with the clutch in. As has been posted, you should have the kickstand up as well. If you're doing all this then get the bike checked out, unless you're handy with the wrench. I'm not.
Sawblade
Hopped up on Mountain Dew
Japan
Actually, I'd check out the clutch switch on the bottom of the lever. The bike wouldn't run at all in gear if it was the kickstand switch.
greenthumb
B.C. Canada
the plug at the clutch lever has been know to come unplugged. its happened to several on this fourum.
that would fit the symptoms you have.
opds9091
cape coral, FL
i think there are 3 safety features
-1 kick stand must be up you can put it on the center stand.
-2 make sure you are in gear
-3 and if you do stall at a light, just shift to 1st or 2nd with the clutch engaged, after that i don't have an answer.
PlasticPig
Fort Lauderdale, FL
Definitely sounds like the connector for the kickstand switch, mine came unplugged and had exactly the same problem, its just under the clutch lever, the black connector will have come out, plug it back in and all will be good.
B
bluenova
Clutch lever switch, not kick stand switch. The bike would not move at all if it was the kick stand switch.
Tailgate
Sacramento, CA
I already know it's the plug just underneath the handlebar on the clutch side. It's happened to me and many others on the forum. Bank on it! Look for a tiny wire harness that plugs in underneath your handlebar---it's loose or disconnected. Plug it back in.
reiobard
Samurai FZ Soldier
Hillsborough, NH
+1 on the plugs that connect the safety switches, they come unplugged a lot and many have found that the clutch one hasn't even been plugged in from the factory...
winkle30
florence/alabama
I had this problem, it wouldnt start with clutch in and kick stand up only in neutral. take it to a yamaha dealer the servos are in the wrong plug, when I took it in the guy fixed it in ten seconds. Im not sure what to call it but I watched him unplub and re plug some switches on the handle bar.
