slikfz6
I ordered the neccesary parts to fix the leak from the water pump. Spent about 40 dlls in parts not bad actually. The problem is the dealer wants 2 hours of labor and at 80 per hour it's actually bad. I put the link which shows an exloded view of the water pump assembly. It seems that the pump is actually sealed and it only has two screws holding it to the block. I bought the impeller, mechanical seal, oil seal and housing o-ring. You guys think I can do this easily, or would it be best to take it in?? Thanks.
2005 Yamaha Motorcycle Parts for FZ6ST FZ6, OEM and Aftermarket at BikeBandit.com The picture is under cooling system!
