Actually I'm thinking about but, need check quality of normal before running consideration. Do you wanna get top end power or fatter mid range? If I will do, I'll install little longer one for 36mm throttle body.
According to parts list, FZ6's one is longer than R6's. I'm understanding this kind of part is influence filling efficiency - long one influence low and mid range and short one influence high speed engine roatation by air inertia(long one will be some fliction for high speed air flow). also curl shape of bell mouse influence. Latest R6 having variable velocity stacks(R1 also??).... Yoshimura finished to divelop "Dual Stacks" for TMR carb having long and short stacks character.
I wonder FZ6 ECU doesn't adjust fuel amount but, FZ6 has intake air pressure sensor.... . However, better shape and good length would helps some range because velocity in intake are inclease at some range(depends on shape and length). I guess to get perfect efficient, we need Power Commander.
Next month, I have big FZ6 owners meeting at "YAMAHA Comunication Plaza" and, "if" I can have opportunity to meet developper, I'll ask question to them.
I might be wrong, but I thought that the R6 has variable intake stacks. They move down on to the TB during low to mid RPM and move up and away from the TB during high RPM. Thus giving the best of both worlds. I think it is called YCC-I (Yamaha Chip Controled Intake).
Am interested to find out myself about velocity stack modifications for the FZ6...especially as i am about to mod my engine, and push capacity out to 636cc, raise compression, and change cams...
Does anyone know if any kits are made for the FZ6, or whether with the modifications i am planning, a change would be warranted in the length of the velocity stacks in the airbox???
Have had a bit of a google, but have hit walls so far!
I've also wondered about these in the past. I haven't seen any FZ6 specific ones, but I have seen 03-05 R6 ones, and if the TBs are they same size like Madman says, they should work assuming there is nothing in the airbox blocking them. You have a PC anyway to tune it afterward. For example Graves Motorsports makes some.
