cookies
ok so i just posted, i wasn't sure if i should post a new thread, or.. just go on with my other one, but it was VERY much off topic, so i will post it here
So six speeds, and learning how to use them. Basically i heard ( at a yamaha dealership ) today, that if you are in 6th for example and you are going 30mph, and you pull the throttle all the way, this WILL damage the engine, is this true, and if so, is there like a guide to what gear you should be in per speed? like when i come out of a corner and i was doing 40 in 5th, ill drop it to 4th , then push it a little then shift back up to 5th, but this seems like alot of uneeded shifting, am i right in my presumption, or am i doing it right? also, is it true about open throttle in a high gear at low speeds? thanks
