TopEnd.tv - Tech Tips - Setting Suspension
MisterX
TopEnd.tv Guy
Madison, AL
www.topend.tv
I don't always post up Tech Tips when they are released, but we've had quite a few requests for this one.
.............. Uhhhhh I feel clueless. I think I'm still going to need help after this video. My rear shock is maybe on 6 my front forks are R6 forks I'm 200 pounds 6"3'. Or is " ' the other way ' " what ever...... Help:confused:
Nice explanation, but it could use a dummy's guide to what these terms actually mean (dampening, rebound, sag, etc.). But otherwise very clear and very well put together. It may also help to elicit how he determined the proper amount of sag for the rider's weight. Just a thought.
Making this more search friendly....
Sag, setup, front spring, rear spring, compression, rebound, measure, suspension tuning, suspension sag
I helped a friend setup the sag on his Brutale, it took several tries and lots of measuring but we got it dialed in for his weight. I can't imagine tearing the FZs forks apart 5 times changing the stack up to get this nailed but I'll be doing it in the months ahead when I replace the springs. Using a good wheel chock makes this job pretty easy with just two people. The Brutale has a side stand, so I leaned it over on that to get the top-out measurement.
Do some reading! This is about dirt bikes so the #'s are different but it gives you an idea. . .
Suspension Setup Tips
is the "30-35mm" quoted in the video an "absolute value" for sport bikes or is it based on a percentage of overall travel?
(pardon me if I'm over complicating things but I'm thinking in terms from setting up my mountain bikes that might have drastic variations in travel (100mm on a cross country bike to say 255mm on a downhill bike))
I think the value is a general reference for street bikes. Some bikes have little or no adjustment.
