Throttle body sync lines
Sdaniels
Goldsboro, North Carolina
Can someone confirm I've got the order correct for the sync hoses? With the tank lifted I see 4 lines, 2 lines pointing back just below & on each side of the airbox. One line is noticeably shorter for each pair. Is the left pair short hose #1, long hose #2 & the right pair short hose #3, long hose #4?
pmmcanon
Spain
May be this is more helpful... You can see the length and shape of each one (also where to attach them)
trepetti
It's all good!
Northern New Joizey
I've got this part figured out...it's the hoses I need help with. Appreciate the info though.
On each pair of hoses, one of them has a 'purple-ish' stripe. These are the #1 and #4 cylinders. Obviously, the left stripe is #1 and the right side stripe is #4.
