Suzuki Is Working on a New VVT for GSX-R1000
Admin
Say Goodbye to the All-Mechanical Setup Suzuki’s current GSX-R1000 has a variable valve timing system it got from the GSX-RR Moto GP bike. It’s an all-mechanical system and a darn good one. However, it seems Suzuki will drop that tried and true system for a new hydraulic VVT system, according to Cycle World. The publication spotted some patent ...
The post Suzuki Is Working on a New VVT for GSX-R1000 appeared first on Web Bike World.
More...
This looks like the same basic dual VVT system that Toyota uses in my 2010 Rav4. Oil pressure controlled through 2 solenoids that are controlled via the ECM, govern advance and retard of the mechanical timing of the cams. There are oil chambers in the cam gears that vary the position of the gear's outer section with relation to the hub section that is attached to the cam shaft. This allows for a much wider performance curve of the engine as well as an added benefit to emissions.
Hmmm.... what ECU will keep up with a bike engines rate of acceleration?
It's about time!
