Gcontroller
After work today went to start the bike to go home. Turned on the key flipped the kill switch to the on position and heard the fuel pump come on as usual. Hit the starter and the motor just turned over not even trying to fire. Went through this like five different times.
Finally took it off the side stand leaned it side to side and tried again nothing. Put the bike in gear and rolled forward slowly dumped the clutch and felt the motor turn over a bit did it again this time in third gear not really trying to push start it just trying to bump the engine over a bit which I did.
I then found netural and hit the starter and she fired right up. Idle was a little slow around 950 rpm but it revved out fine and I rode home 40 miles. Not really sure what to think. I did just top off the tank right before I parked it in the morning and the temps got over 80 degrees today so it was warm.
So I wasn't sure if there could be some kind of vapor lock possible but I did open the fuel filler once to see if there was pressure in there which there wasnt. It's gotten plenty hotter in that parking lot with a full tank before.
So I'll keep a eye on it and see what happens.
