david223
I don't understand what happened here, hoping someone can explain it...
Just before going for a ride, I noticed the left bolt on the front of the gas tank was missing. So I start her up, ride to the dealership to order a new one, then go for an hour ride, get home and park in my garage.
Eight days later, I'm set for a full day ride that had been planned for a couple of months, all geared up and packed. I get on the bike, and it barely turns over! Now this is a new battery I installed in May, but it's a cheapy and I figure okay, it's been sitting over a week, maybe that's all. I put on the charger and after 30 minutes or so, it says it's charged. I try to start it, hardly turns over again.
I raise the tank to check the connections, and guess what I find? The missing bolt from the tank had fallen onto the battery, with the washer bridging the negative terminal to the frame of the bike. I remove the bolt and set the charger again. This time it takes a few hours to reach a full charge, and when I try it, it starts fine.
The next day, dead again. I charge it again, take the bike out for a 45 min ride, keeping the rpms high just for that extra boost. Next morning, no go again. So the battery takes a charge, but won't hold it overnight.
My question is how can a short from the negative terminal to the frame drain and then kill my battery? I can understand a short from the positive, but the negative?
The obvious solution is to get another battery, but I just want to understand what happened!!
And to top it off, I can't find the receipt from when I bought the battery!
