awill1
While riding through the Sierra Nevada mountains my 2005 FZ6 was stalling every time I came to a stop. Instead of a violent motion like in my earlier riding days, the engine just seemed to slow down and fade away. The first few times I thought I might be doing something wrong. Then I began to worry that something was wrong with the bike. It was running normal when I was moving, but once I let off the throttle the engine just faded out. The route I took only had a few stops, so after only a few stops I descended from the mountains and there was no more problem. Once in the valley I switched to the digital tach and the idle rpms were normal.
Is there a good reason my bike would have this behavior in high altitude? Do I need to switch the key to off and back to on to let the ECU adjust to the lower air pressure? My bike is completely stock. Should I take my bike in for inspection before I make the return trip home? I really don't want to ride home if something is wrong.
Thank you in advance.
