bmccrary
Touring Mod
If you can find that image that some one posted of the full system (headers and cans) you will see where the gains are made.
On our system all 4 header pipes merge into one at the same point. This system works, but is not the most efficient for our small displacement. If you notice on full systems the exhausts will go from 4-2-1 as opposed to the 4-1 we have now. This allows for a less turbulant flow and disruption at the collector. In turn, allows the exhaust to evacuate they cylinders quicker, ie makeing for a more effiecent charge.
Fact: When the motor goes through the exhaust stroke, the cyclinder does not completely discharge all of the burnt gasesm, it is not a perfect system (Nothing is). There for the engineers at Yamaha set up the fuel system to release enough fuel to each cylinder, accounting for the amount of burnt gases that remained from the last cycle. So by having a more straight through exhaust you are able to evacuate the cylinder faster which allows more to escape and leaning out your mixtures.
To compinsate, adding a bit more fuel and having a cleaner charge results in the power gains.
Hope this helps.
-bryan
Hope this helps.
-bryan
