she wont stay running??
mattboy
spain
Hi there, new to this forum hoping someone can help?
I got hold of a 06 FZ6 that had done 1800miles and left standing since then????????Criminal!!!!
Pulled the tank off and looked inside and was thick in stale fuel/varnish so was the fuel pump. I cleaned tank and pump assy,removed injectors and cleared all pipes and so on.
Re-fitted the tank, now the pump runs when the ignition is on and if i wind the throttle back to its stop (flat out) and back to idle she fires up but shuts down within 10 seconds as if it is running out of fuel???
I am guessing new tank, fuel pump assy and maybe new injectors should sort it but just checking to see if it could be shutting down due to a fault code or ECU fault.
I have spend some time cleaning the fuel system, but may be is just needs new as the pump was so blocked up it was siezed and blew a fuse when i first tried to start it????
Anyway seems a shame to let her rot any more and really want her back on the road as the bike is like new with low low milage, any help would be great.
Thanks for your time in advance
Matt
Can you get something like this--
Sea Foam | Products
The engine treatment on the left is the one that should clean the fuel system.
Put at least 1 oz per gal and start the engine to get the cleaner through the system and then let it sit and soak for a while then try and start again, might work. I have also heard that Chevron Techron works well --
Cars Love Chevron with Techron
Let us know what worked out for you.
Jerry
is the tank rusty? if not, you should be able to just
clean the system and get it going, try that product
listed above...it may take several tanks of gas to get
it running properly
thanks for the replies, i will try some injector cleaner. the tank is not rusty but is still has ols fuel/varnish in areas.
trouble with the injector cleaner is the bike will not run long enough to get it through the system......but i will try. let ya know
thanks
