I just installed the Rizoma LED rear turn signals pictured below.
The problem is that the rear turn signals do not work now. Furthermore, it appears I have blown the rear license tail plate light fuse. When I connected the factory turn-signals they worked with out a problem, but the rear plate light still does not work.
Here are some shots of the wiring for the aftermarket signals.
This is a shot of the original rear light connectors on the bike.
Photo below shows the black small box coming off the rear right signal light which in turn connects to a adapter cable to fit the factory wiring. The adapter cable come with three cables; red, black and red+white (which I think is ground and does not to be used?).
Below I simply match black male to black female and red male to red female on the adapter. Then I simply plug in to the bike's terminals as shown on picture 2.
As you can see the other end of the adaptor is designed to fit in to the bikes terminals. I made sure I matched the Left light to Left, etc.
After the wiring is complete the turn signals do not light. We've already established that the tail plate light probably has a blown fuse so that does not light either.
Suggestions? Help please. Otherwise I'd have to visit a local stealership for help.
Thanks in advance.
Thanks in advance.
