Bonner
I have just replaced the pads, brake lines fluid and cleaned out the calipers. The seals seemed pretty good (Clean, flexible no damage) so I just re-used them. The problem is that I now have a pulsing squeak in my rear brake. You can hear it at low speeds and the disk gets quite hot so it's definitely making contact with the pads.
What could be causing this? I've re-bled the system and there was a little air still in there (Which I removed). I'm dreading that it's going to be another warped disk, because it always seems to happen with bikes I own, even though I don't ride hard.
