firsttimefz
anyone out there done it. worth the cash? what kind of performance are we looking at
You will lose roughly 10mph on the top end but getting there will be much easier
That conversation rings a bell
with -1/+2 i can bounce the rev limiter no problem in 5th. with stock gearing i cant get
there reasonably. so being able to shift into 6th, im probably able to reach the same or higher top speeds. btw, ive hit an actual 146 in 5th (or maye just into 6th) stock, but the bike had pretty much pooped out.
He says he hit 146mph actual on his stock FZ... which we can all pretty much confirm.
He did not mention his top actual speed after the -1/+2 though... which is what we`re asking right now I`d still bet you wouldn`t get to 146 after the conversion.
The bike is not way faster, you actually lose speed in each gear, but you gain torque because you`ll be higher in rpm for a given speed, so you will get to 100mph faster, but the question is will you lose top speed on the FZ, since you can`t redline in 6th anyway.
Some ppl think that because you`ll be able to use the more "useful" part of the power band, you`ll be able to go faster in 6th... I have doubts
But anyway, I am going to perform my own test and report back shortly :thumbup:
Your torque per given speed (not rpm) will be higher though, since you are now in higher rpm for any given speed, and we know we get more torque on the fizzer the higher the rpms (until you pass 11k-12k, then torque decreases again).
Sorry, I have to do it - So where did we get to on this? Has anyone had time since August to give the -1/+2 a real world test or are we all still guessing??
Also, where can I pick up a 15T fromt sprocket? I assume any make will be ok or is there some super-duper flashy colored one I should get?
The other aspect is that adding a tooth would make the speedometer just about right.
