Quick wiring question...
Fbrand619
Noob on bigboybike
San Diego
Hello everyone. I am working on a project bike and have a quick wiring question. Looking that the manual kind of confused me so I'm hoping to get better luck in the forums. Below is a pic
I have circled 3 connectors and was wondering if anyone can tell me where they go. The white one the brown one and the black one. Thank you for looking at this thread any help would be greatly appreciated.
It would be a big help if you can look at wires and give the best color description you can. Number of pins on the plug are also a help in identifying the wires. Are they just unused plugs or do you suspect they were plugged into a component?
Also I'm in San Diego! :)
Fbrand619
Noob on bigboybike
San Diego
The white plug is light blue with grey dots.
The brown plug is yellow with brown dots and brown wire.
The black plug is black wire with blue and a gray wire.
I hope I described it properly. Thank u so much for your help.
The white plug is light blue with grey dots. Probably blue with green dots was the original color code = Sidestand switch.
The brown plug is yellow with brown dots and brown wire. I found a plug with a yellow and a brown wire. = Rear brake light switch.
The black plug is black wire with blue and a gray wire. I found this same color = Crank shaft position sensor. (right side of the engine)
The color code you gave me didn't exactly match up to the schematic color code but these are the closest per plug and colors I could find. :)
Fbrand619
Noob on bigboybike
San Diego
Thank you guys so much for the help. Any chance someone can take a pic of where the 3 plugs plug into? I've been looking everywhere in there and can not seem to find where they go. Unless I'm missing something.
Fbrand619
Noob on bigboybike
San Diego
Okay so i found the cam positioning sensor plug the black one.
I'm still stumped at where the white plug goes sand where the brown one goes.
I followed the kick/side stand and it was connected.
The brown one that is for the rear brake light switch I can not find where it plugs to.
Once again thanks for the help.
Maybe the best bet is as some suggested is take a picture and match the plugs. Did you disconnect the fuel pump and fuel level sensor?
Fbrand619
Noob on bigboybike
San Diego
I was able to locate the 2 plugs that goes into the fuel tank.
The 2 wires I'm talking about is the other two the one with the brown plug and the one with the white plug. There is nothing near them that they can clip into.
The diagram says its the side stand but the kickstand is plugged in.
The brown one is the tail light switch but I see no connectors near it in that area.
Once again thank you for your time.
Fbrand619
Noob on bigboybike
San Diego
Success.. I have found where they went.. Once again I would like to thank everyone for there help.. I step closer to getting this bike on the road.
@Motogiro what part of SD? Once I get her street legal would love some riding pointers...
I'm in Sorrento Mesa area. I don't know if you can get out midweek but I'll be out for a ride with Neal next Weds...:) Maybe this Sat or Sun?
